Results 1 to 3 of 3
Thread: Rinse Aid
    Titchfield
    Geoff T
    1,673
    Default Rinse Aid
    Hi Guys
    I hear that it's possible to use a dilute solution of rinse aid, after washing and rinsing the car, to prevent the dreaded water marking, does anyone know if this works and is it safe for the paintwork etc?
    At the moment I'm using de-ionised water, but the media requires frequent replacement.
    Dec 2009
    Slapshot
    513
    After rinsing with tap water I dry with Meguires Last Touch undiluted (but it can be used 1:1 with water). This in combination with Auto Finesse Aqua Deluxe drying towels.
    3,386
    To prevent water marks use one of the water filters then you no longer need to dry the car off with a towel etc. (equivalent if what modern window cleaning systems do where you don't squeegee the window off).
    However, saying that if you do as I do and add a bit of Demon shine (rinse aid/polish) to a watering can of filtered water then in effect water your car not only does it not spot it also leads to very little water being left on the car which can be easily be mopped up plus helps retain the beading effect.
  1. Dream Rides Event in aid of Libby Lee
    By mal in forum Charity section
    Last Post: 31-05-2010, 12:45 PM
  2. 2010 CS Calendar in aid of Littlehavens Hospice
    By F355GTS in forum Ferrari Talk
    Last Post: 05-10-2009, 03:08 PM
  3. F430 to aid Abruzzo
    By Gemm in forum Ferrari Talk
    Last Post: 14-05-2009, 09:24 AM
  4. Replies: 2
    Last Post: 06-07-2007, 12:39 PM
  5. Soccer Aid
    By stevew in forum Motorsport and Sport
    Last Post: 31-05-2006, 12:17 PM
