Results 1 to 10 of 15
Thread: 348 HVAC snag
    11,785
    Default 348 HVAC snag
    Before I start tearing things apart just wanted to see if anyone had come across this before.
    The HVAC on my 348 works perfectly (that's not the bit I want o find out if anyone has experienced) - hit the heat button and you get hot air, selecting AC gives a blast of cold air....... well a breath of it anyway. Temp controls seem to work and selecting the different vents all seem to get hot or cold air coming from the right place. All is good then
    Snag is what the unit itself is saying - the readout is just nonsense with random parts of characters lighting up when you push different buttons, hitting the AC button lights the heat button up and hitting the heat button doesn't light anything up. I can't fathom how you can press the AC button, have the light indicating heat light up yet get cold air?!?!?
    I've done the normal searches and thus far Google has been less than helpful......
    11,785
    6,709
    Try dropping Eugenio (flyingboa) a PM, I think he had this problem but not sure how it was resolved
    11,785
    Thanks, will do
    3,674
    If it were me I would check your "hidden green fuse" first if you've not already had it modified/replaced. Easy check to do that just requires the corner of the front boot compartment lifting and a torch shining in.
    If above is good perhaps take out the AC unit and clean the connections and reinstall. Again easy to do, ie remove coin holder, then ash tray, gear suuround then ac unit.
    Are all other other electrics behaving ok? Is battery good/charging ok?
    760
    Agree, give it a good strip down, plenty of contact cleaner. I also enlarged the holes the buttons sit in very slightly as I found they would 'stick in' causing issues.
    11,785
    Cheers Mate. Yep, all other electrics are fine and battery seems fine. What's really got me stumped is that when you push a button you get the desired result yet a button you don't even press lights up?!?!? Will check the fuse (located a thread showing where it is exactly and how to get at it) and then move on to taking the HVAC out and cleaning connections, also suggested by Matt. The only reason I've been sitting on my hands is because right now it works. Sods law says it won't after I take it out. Eventually the wrong buttons lighting up will irritate me though.
    Quote Originally Posted by Quigs View Post
    Cheers. Yep I think it'll have to come out. Ricambi (spelling?) have a good vid on how to remove them, looks relatively straight forward.
    Mar 2013
    Matt
    1,173
    Sounds to me like job one should be to unplug, clean , replug.
    Wouldn't be surprised if joy ensues.
    11,785
    Quote Originally Posted by J70 View Post
    11,785
    Had a go at sorting this out today:
    http://www.youtube.com/watch?v=a5c7nmPWQug&autoplay=0
  1. HVAC ...LED needs soldering...help
    By lotusk in forum Technical Q & A
    Last Post: 06-12-2015, 04:11 PM
  2. HVAC Air Flap Help!
    Last Post: 06-10-2014, 08:16 AM
  3. AC snag
    By Nosevi in forum Galleries and Members Cars
    Last Post: 19-05-2014, 10:46 AM
  4. 348 HVAC Code E2.
    By J70 in forum Technical Q & A
    Last Post: 07-08-2013, 04:26 PM
  5. 348 minor engine snag
    By Nosevi in forum Technical Q & A
    Last Post: 08-08-2012, 11:57 AM
