Results 1 to 10 of 13
Thread: Ferrari 348 Gas Analyzer Results
    Sep 2018
    Haydar Kirmani
    9
    Default Ferrari 348 Gas Analyzer Results
    Hi all
    I've been having an unusual judder/vibration problem with my car at low rpm and so I decided to use a gas analyzer to see how the car was behaving. What I found was a big different between the two banks. I've posted pictures of the two readings, these were at idle with the engine warm. Would appreciate it if someone could help me understand the readings. I have removed the CATs in my car and replaced them with straight through pipes.
    Name:  Gas Analyzer 1.jpg
    Name:  Gas Analyzer 2.jpg
    11,230
    Those do seem quite out of kilter, the carbon monoxide and hydrocarbons on the first bank are way too high (if I’m reading it right!). First thing I’d do is clean all connections (MAFs TPCs HT leads etc), clean MAFs, check resistance across both MAFs and do a full ECU reset. If after that the imbalance remains I’d start digging deeper.
    Ask on here if you need any help with any of the above
    Allandwf is offline Essex boy's Ford Capri Club Member
    Jun 2009
    Angus, Scotland
    Allan Fisher
    143
    Default Readings
    You could easily swap the MAFs over and see if the readings follow.
    132
    High CO suggests to me incomplete combustion.
    Your HC is high (unburnt fuel) so almost certainly a misfire
    High Lamda reading sometimes is caused by an exhaust leak but yours seems very high so perhaps an excess of air.
    Sep 2018
    Haydar Kirmani
    9
    Cleaned all connectors and checked MAF/TPCs/HT leads. Resistance across MAFs is identical and spot on. If by ECU reset you mean disconnecting the battery for 10 minutes and then letting the car idle for 20/30mins, then have tried this too.
    Sep 2018
    Haydar Kirmani
    9
    Not sure if there is a leak in the exhaust system, but the car has some bespoke exhaust so don't know if this could be issue?
    Could this be a valve timing problem? Maybe the timing is out by 1 tooth when it last had the timing belt changed?
    Pangea's Avatar
    Pangea is offline Only 37 known common faults - The Ferrari 355 Club Member
    1,008
    I wouldn't say those readings are particularly out of sorts for no cats. Similar to mine, but you can't measure the individual banks accurately through the tail pipes. Ok for MOT. For tuning and diagnosis it should be done through ports on the secondary air pipes. Ref. Workshop manual. Page C 85. I presume they mean the small connector on the curved pipe in the pic. It is covered by a small domed nut although Ive not had to use these myself yet. Im also just doing a retro fit of the diagnostic buttons which connect to the main ECUs. You can fit bulbs into the spare ports in the dash and then carry out code reading for each bank. They didn't fit it to euro cars. I don't believe this is for 2.5 Motronic though. Check the video. https://www.youtube.com/watch?v=PKFhGWLM0i0
    Probably would be a help to you. There are a list of codes in the WSM.
    Ive not finished just yet but will post it in my thread. I don't know if you speak French but have a look here. http://ga68.free.fr/autre/FERRARI-34...i_348-V211.pdf
    Name:  Secondary air pipe .jpg
    Sep 2018
    Haydar Kirmani
    9
    I've fitted the bulbs into the spare check engine ports in the dash and both lights go off when I start up the engine. I know they are working since if I disconnect the MAF the light on the relevant side stays on. Do you have instructions on how to retro fit the button to the ECU, my car is an early 348 so has the 2.5 Motronic.
    Pangea's Avatar
    1,008
    Quote Originally Posted by haydar View Post
    I don't believe this will be applicable for 2.5. Do you have this loom present by the ECU? The black plug at the bottom of the picture above the test button mount. It has a blanking cap fitted here. Its on the end of approx 20cm extension coming from the main ECU loom. You need this to connect the test button.
    132
    Never seen a lamda reading that high from an exhaust leak.
    I would have thought you would have noticed rough running immediately after the belt change if the cam timing was out
    Presumably you have the lamda sensors on what was the cat inlets. If one had gone down then it might be feeding wrong info back to its ecu?
  1. 348 re gas ac
    By 308rosso in forum Technical Q & A
    Last Post: 26-09-2009, 12:48 PM
  2. 348 Air Con Re-Gas Procedure
    By Siban in forum Technical Q & A
    Last Post: 25-09-2007, 12:46 PM
  3. 348 TB AIR CON RE GAS
    By stevenew in forum Technical Q & A
    Last Post: 26-07-2007, 12:43 AM
  4. 348 Spider Dyno - Excellent Results
    Last Post: 19-03-2007, 07:00 PM
  5. Interesting 348 dyno results
    By ferrari-spider in forum Ferrari Talk
    Last Post: 16-08-2006, 10:27 PM
