Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: Ferrari 308 Project Rebuild and Euro Conversion
  1. #21
    Apr 2006
    Whyteleafe
    Simon Stroud
    1,322
    Default Great Thread
    Great thread, I know what it's like to restore a car in a single garage with a single drive. Hats off to you particularly looks very cold.
  2. #22
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    Good luck with your project.
    I just had my first look at your youtube (episode 9 ) and just an observation I think they are too long with repeating the same information, and I think they would be better if you where more concise. e.g you could have said I got a new compression tester today and turned the first two minuets into 5 seconds
    Yes totally appreciate the feedback, all taken on board. With this build the car was a none runner purchase so its a bit of a journey that's happening real time with everyone along for the ride with me, discovering all the issues as they appear.
  3. #23
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    I would start looking at the valvetrain on the affected bank; It would be very unusual to have a bore issue on all four cyls leading to the same compression figures.
    Yes agree will certainly be doing a lot more investigation prior to pulling the engine.
  4. #24
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    Caught up tonight and enjoyed the vids to date.
    i must say I admire your commitment working on a narrow drive in winter with no weather protection or light. Iíll not complain about my narrow garage again
    Iíd echo the other comments about a possible valve timing issue......
    Keep the updates coming......
    Thanks Mike appreciate the encouragement. I have just sold one of my 355's now so shortly will have another garage space. The dilemma now is I also wanted to pull the engine on the Ratarossa and do a full refresh, belts, pipes etc this winter the extra space had been earmarked for that. MMMMmmmmm what to do 308 or Testarossa.
  5. #25
    francisn is offline Post whore with no life, no friends, and a problem fitting into normal social circles Admin dude
    S. England, but Scottish!
    Francis Newman
    17,061
    Hi Scottie, just found time to look at all the episodes. Good stuff.
    Is that at your house or somewhere else? I don't recall that narrow drive.
    I'll give you a call and pop round to see progress after Xmas
  6. #26
    Jun 2006
    South East UK / Hamburg
    Candellara
    6,309
    Great project Scottie
    As others have said, check the cam timing on the rear bank before pulling the engine. Has a the belt jumped a few teeth? Strange to see all four cylinders down uniformly across the whole bank
    Has someone changed the belt and messed up the timing on that bank?
  7. #27
    Jun 2006
    Candellara
    6,309
    Quote Originally Posted by candellara View Post
    Forgot to mention. Compression test should be run with all spark plugs removed, coils disconnected so it doesn't try and fire and throttle in wide open position.
    Might be worth checking the belt timing and then re-running compression test
  8. #28
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    Quote Originally Posted by francisn View Post
    Cheers Francis
    Yes the 308s are not at my house (lack of space). They are not far from your place though if you fancy popping over at some point in the project to have a look.
  9. #29
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    Really appreciate all the comments, helps me try and figure out what to do and next steps in the project.
  10. #30
    Oct 2009
    Wokingham Berkshire
    Scott
    265
    Started to strip the various bits off the car today in order to figure out why that rear bank has low compression.
    https://youtu.be/xYpXpNhj-bc
  1. 308 With a Dino Body Conversion???!!!! Yikes
    By irarref in forum Ferrari Talk
    Last Post: 07-12-2013, 05:19 PM
  2. F355 rebuild project
    By David007 in forum Ferrari Talk
    Last Post: 28-04-2013, 11:28 AM
  3. 308 QV Euro - Change clutch cable ...help anyone ?
    By jasper_40 in forum Technical Q & A
    Last Post: 10-02-2013, 08:28 PM
  4. Why is a Ferrari engine rebuild so expensive????
    Last Post: 15-10-2012, 06:35 PM
  5. £500 Ferrari !! - Another cheap rebuild project ?
    By 400SPYDER in forum Ferrari Talk
    Last Post: 22-02-2006, 10:39 AM
