Thread: Ferrari 348TS in exceptional good condition and historie
    Cauf61 is offline Burnt out Rover Metro Club Member
    May 2018
    Belgium
    Patrick
    17
    Default Ferrari 348TS in exceptional good condition and historie
    For Sale Ferrari 348 TS from 1991. Has run 61500 km. The car is in exceptionally good condition. This for bodywork (extra treated against rust), leather interior and engine. Motor runs perfectly without oil consumption.
    Overall condition 8.5/10.
    The large service, incl. clutch! ,was executed in 5/2018 on 59000km. Very extensive history available. Original Tool case + Ferrari map with manual is still present. Air Conditioning and HVAC unit work as it should. The Rest of the electro also works as new.
    Last services:
    Water Pump Heating 1 2-9-2017
    Switch Mirror L 1 2-9-2017
    Fan Regulator 1 2-9-2017
    Dampers Trunk Lid 2 10-10-2017
    Rust treatment noxudol700 23-12-2017
    Clutch + NEW Plate 1 25-4-2018
    Belt Camshaft 1 25-4-2018
    Set span Rollers HILL eng. 1 25-4-2018
    Belt Alternator 1 25-4-2018
    Crankshaft Phase Sensor 2 25-4-2018
    Lubrication + overhaul Flywheel 1 25-4-2018
    Gasket set "Large " 1 25-4-2018
    Gasoline Filters 2 25-4-2018
    Brake Line 4 25-4-2018
    Drive shaft seals HILL Eng. 3 25-4-2018
    Crankshaft Seal Viton 1 25-4-2018
    Drive shaft BEARING HILL 1 25-4-2018
    Pressure BEARING clutch 1 25-4-2018
    Shim Camshaft 5 25-4-2018
    Oil Shell Helix Ultra 5W40 11L 25-4-2018
    Thermostat 1 25-4-2018
    Oil Filter 1 25-4-2018
    Wear block chain Tensioner 1 25-4-2018
    Replace Kluber Grease 1 20-5-2018
    Also on youtube : "ferrrari 348ts for sale "
    Paul
    251
    Lovely car. Do you have pictures of the interior? The last 2 services are impressive in terms of what was done... seems like you spared no expenses.
    Giving us a sense of the car service history (dates) would be useful, as most european cars donít get serviced every year, which is more frown upon here in the UK as it does on the continent.
    Finally, getting us a sense of what youíre looking to get for the car would be helpful.
    Good luck with the sale.
    May 2018
    Belgium
    Patrick
    17
    Quote Originally Posted by rivarama View Post
    Giving us a sense of the car service history (dates) would be useful, as most european cars don’t get serviced every year, which is more frown upon here in the UK as it does on the continent.
    Finally, getting us a sense of what you’re looking to get for the car would be helpful.
    Hello
    The car is in more detail also on "classic trader" and on you tube. Search terms : "1991 Ferrari 348ts for sale" Clip is about 1 week old now.
    11,099
    May 2018
    Belgium
    Patrick
    17
    Default Price drop
    Hello As the folding roof is as good as sold i lower the price a bit to 60.500 euro.
    Grts Patrick
    May 2018
    Belgium
    Patrick
    17
    May 2018
    Belgium
    Patrick
    17
    Default PRICE DROP !
    Price drop to 59900 euro !
  1. Alonso, Ferrari would be 'an exceptional duo'
    By tonyh in forum Motorsport and Sport
    Last Post: 08-01-2009, 01:48 PM
  2. Replies: 0
    Last Post: 17-08-2006, 01:19 PM
