Page 34 of 34 FirstFirst ... 24323334
Results 331 to 337 of 337
  1. #331
    giles's Avatar
    giles is offline Toyota MR2 355 replica Club Member
    275
    Update to parts ordered from Eurospares:
    Heat shield is not available so Iíve tried the main dealer, apparently they can get a couple, we will see.
    No sign of the other parts from Eurospares so I may have to be driving to the south of France before all the new stuff is fitted, gulp!
    Iíve also had to buy a new battery as the display shows up an ASR warning if it hasnít been plugged into the CTEK for a day or two. The research I did shows it takes a 096 battery, but not all fit.
    Originally from Halfords for £100.80 with the trade card I got a Yuasa 5000 with a 5 year warranty, pretty good I thought but it didnít fit, couldnít quite get the bar over the top, combination of the ledge being too high and or it being slightly too deep. So I got from Tanya batteries a AGM YBX 9096 for £130 delivered with a 4 year warranty, it fits perfectly and it has exactly the same current and cold crank amps as the OEM battery.
    I know people swear about the Oddessy batteries with their compact lightweight design but I couldnít figure out which one would fit the bill.
    Iíll try and get a couple of photos.
    2,537
    Quote Originally Posted by giles View Post
    About to trip over 177k and next month Iím off to Cahors, so itíll have a few more soon!
    Stonking. Ferrari should give you a medal!
  3. #333
    giles's Avatar
    275
    Battery photosÖ.
    The Yuasa has the same dimensions and Amp hours and Cold Crank Amp value and itís also an AGM (absorbent glass mat) battery like the Ferrari OEM battery.
    The AGM is mostly a positive thing but you do need to be careful when charging. My CTEK MXS 5.0 has an AGM charge mode, so I guess logic suggests that if you donít have that mode on your trickle charger you should do a spot of research before you charge an AGM battery?
    Pic of CTEK taken while charging a non AGM battery!
    Ordered parts update: nothing arrived yet!
  4. #334
    giles's Avatar
    275
    Thumbs up
    Everything from Eurospares has now arrived, so now just waiting on the driveshaft rubber boot heatshields from Graypaul Ferrari Birmingham.
    No time to get this done before we drive to the South of France so I'll get it booked in for when I get back.
    Hopefully some photos from France to come soon
    12,053
    Always fun to get a goodie package from Eurospares, look forward to seeing it all fitted.
    Have a fun trip south
  6. #336
    giles's Avatar
    275
    Arrived at the Air B&B in Montauban, car didnít miss a beat but I have had a part failure! Iíll take a photo later
    A few photos so far:
    Low ground clearance cars get priority disembarking
    Hot hot! Can this be changed to Celsius?
    Grand tourer!
    Overnight stop at a motel in Chateauroux
    Tight fit but gated private parking at the Air B&B in Montauban is a welcome bonus!
  7. #337
    giles's Avatar
    275
    Could this be the most minor ever part failure? I might just rubber super glue it (Loctite 406):
    You can also see in the photo the lower buffer that fell off a few months ago, so a new one is hopefully part of my goody box from Eurospares
    Certainly easier than removing this, not sure how to remove this body mounted tethered link to the fuel cap
