Results 1 to 10 of 10
Thread: Repairing F355 fuel sender
    Feb 2006
    Kwang
    369
    Default Repairing F355 fuel sender
    Mine is faulty one, reads empty, red light mostly. Any ideas? Occasionally moves but inaccurate, from 3/4 full to empty within the same drive. By the way they are not available new any more.
    Mar 2015
    Sydney
    Ian Riddell
    104
    Quote Originally Posted by sim View Post
    Assuming it's not the gauge...
    https://www.ferrarichat.com/forum/th...pinion.596552/
    Feb 2006
    Kwang
    369
    Quote Originally Posted by Qavion View Post
    Thanks, I saw it, looks fiddly...and parts that goes in the tank may react with fuel.
    Mar 2015
    Sydney
    Ian Riddell
    104
    At a price, you could have one custom-made by a company such as Isspro
    https://www.isspro.com/page.php?page...O_Fuel_Senders
    I had one for an '89 Lotus Esprit made up. If they don't already have a blueprint for a F355, you would have to provide dimensions, number of wires, trigger levels (in ohms), hole pattern, etc. They send you a form to fill out. Unfortunately, the US dollar is quite strong at the moment.
    Feb 2006
    Kwang
    369
    Thanks, I have sent them an email, see what they say. What kind of price are you talking about? Repair would be a first choice.
    Mar 2015
    Sydney
    Ian Riddell
    104
    Sorry, my memory is a little fuzzy. It was quite some time ago. It could have been U$300.
    I'd be curious to know what they actually quote you.
    Feb 2006
    Kwang
    369
    Sent one to them. They cannot repair or reproduce.
    Any more ideas?
    Jun 2019
    Welsh Borders
    Brian R
    14
    Default Fuel sender issues also
    Any more ideas?
    I was just going to ask the same question! Have you made any more progress with a repair?
    I took mine out last year and it had corroded away with the u/l fuel separating from lack of use. Also needed new fuel pump and rubber parts, all disintegrated! Got that sorted but gauge not so good. Annoyingly they were still available then at around £300 ish I think and I jibbed at the price. now 5 times that if available at all........
    I tried to make some new parts for the sender, seemed to work on the bench but when refitted, the gauge doesn't move and the light on all of the time; that was last year and now I thought I have some time to sort it !
    Jun 2019
    Welsh Borders
    Brian R
    14
    Default Repairing F355 Fuel sender
    Any more ideas?
    I am working on a solution for this, all being well!
    Please let me know if you would like more info on cost, lead time and what's involved.
    Thanks
    Jun 2019
    Welsh Borders
    Brian R
    14
    Default NEW 348/355 replacement fuel level sender available soon
    In collaboration with a fuel level sender specialist, we have designed a direct replacement for the original Ferrari item but using 21st Century technology. On initial tests it worked perfectly, with a nice steady movement of the gauge from Empty to Full and the warning light is triggered at around 10-12 litres. Having now completed the design of the fitting parts, it is finished and a prototype will be ready for me to test in the next couple of weeks. Once that is signed off, I will be ordering a batch and make them available to everyone. It will be supplied with a new genuine gasket seal and wiring plug and with the option of an 'economical' specialist fitting tool which is required to remove and refit the unit.
    Please PM me if you would like more info.
    Many thanks, Brian.
  1. Wanted 348 fuel tank sender
    By smilesoffun in forum Wanted
    Last Post: 16-05-2019, 07:38 PM
  2. F355 fuel issues
    By virendra in forum Technical Q & A
    Last Post: 07-05-2011, 10:21 AM
  3. 308 Fuel Sender Orientation
    By AndrewE in forum Technical Q & A
    Last Post: 27-06-2009, 09:31 AM
  4. Help with changing an F355 oil Pressure sender unit…
    By New to this in forum Technical Q & A
    Last Post: 03-07-2008, 09:31 AM
  5. Fuel Sender failure
    By Davo456 in forum Technical Q & A
    Last Post: 29-10-2006, 03:16 PM
