Results 1 to 3 of 3
Thread: Removing electric window switches on F430
    Nov 2019
    Surrey
    Dino Leone
    1
    Default Removing electric window switches on F430
    Hi everyone, I'm new to this forum and have tried to find the answer to this question within the forum but cannot seem to locate anything relevant.
    I have the usual 'sticky' switch syndrome and would like to remove the electric window switches to clean them off (or replace them).
    I cannot find any instructions anywhere on how to remove them, but it seems like it should be quite easy......hmmmm.
    Before I start, I was wondering if anyone here had previous experience that they'd like to share before I inadvertently break something...
    I'm guessing that to access the switches I need to remove the carbon fibre 'centre vent' panel which appears to be held in place with 2 screws underneath the plaque...is there more to remove than just that?
    Do I need to remove the vents before the panel comes off?
    Any help is gratefully received.
    Tackleberry's Avatar
    Tackleberry is online now Del Boy's Reliant Robin Club Member
    May 2014
    Poole, Dorset
    Anthony Gnapp
    70
    Hello Dino,
    In addition to the Screws under the Plaque you need to remove the Stereo Unit. This then gives access to two more Screws.
    Remove these, then pull the Panel forward.
    Unplug the Connectors, then on the the back you will see the Screws that retain the Switches.
    Undo these and your Switches are free !
    JohnJStewart's Avatar
    JohnJStewart is offline Only useful for school runs - The Ferrari 308GT4 Club Member
    Mar 2008
    Richmond, UK
    John Stewart
    582
    Default Sticky switches
    Quote Originally Posted by f1dino View Post
    Sign up on YouTube or plain old web for Normal Guy Supercar for tons of great F430 repairs including this one.
    https://www.normalguysupercar.com/fe...ttons-removal/
  1. 308 Window Switches
    By guappo in forum Ferrari Talk
    Last Post: 03-06-2016, 05:32 PM
  2. 550 Electric Window Positioning.
    By Gomez in forum Technical Q & A
    Last Post: 15-12-2014, 08:43 PM
  3. 308 GTS QV electric window fault
    By Tonym3 in forum Technical Q & A
    Last Post: 22-04-2012, 05:50 PM
  4. F430 electric window and remote locking problem
    By F1RGY in forum Technical Q & A
    Last Post: 08-09-2007, 09:23 AM
Tags for this Thread
