Results 1 to 4 of 4
Thread: Ferrari 575 Model Year changes? What to look for?
    Mar 2009
    Aberdeen, Scotland
    lamo22xx
    143
    Default Ferrari 575 Model Year changes? What to look for?
    Hi everyone, looking for some help & advice here. Does anyone know what/if any were the updates done to it throughout production? For example was the F1 gearbox ever updated? 360 was improved in 2003 for example. If not are there any options to improve it? For example I know challenge stradale software can be put on a normal 360.
    I believe there was the following options, standard car, then a handiling pack was offered, then the GTC handling pack. Is that correct? How big a difference do the handling packs make?
    Is there anything else that is worth knowing?
    Thanks in advance
    6,670
    You definitely want one with the Fiorano handling pack although later cars (late 2004 on) had a number of the pack features as std. If you find one without the parts can be retrofitted if they can be found. Exhaust also changed in 2004, think the middle boxes were deleted and replaced with an x pipe, at this time there were a few very minor other tweaks inc.a rear 575m badge and slightly re-profiled boot/ rear bumper. I've heard the HGTC gearbox s/w can be applied to earlier models
    19,134
    I disagree completely about FHP after about 30000 miles without ! The myth began (probably) because the first test cars had an early suspension ECU which almost certainly no car you would be looking at today still retains
    One option is/was just to change the steering ECU for the FHP version but I went back mainly to have easier steering in London
    There's a wonderful chap called Taz at Ferrarichat who knows more than almost anyone about 575 so read & learn there
    He also has a changes sheet available which may have been updated since attached - very few apart from some sort of proportionality in the steering for about the final third of production
    Attached Files Attached Files
    Halifax,
    ian
    1,667
    Get a manual...or a 550
  1. [VIDEO] Nissan GTR - Model year 2011 interviews & presentation
    By Angelis in forum Other bikes, cars and toys
    Last Post: 15-12-2010, 05:02 AM
  2. 360 model year difference
    By khooni in forum Technical Q & A
    Last Post: 19-02-2008, 08:38 AM
  3. 612 Model Year changes
    By LWR in forum Ferrari Talk
    Last Post: 17-05-2007, 06:36 AM
  4. 512M - model year spec differences
    By Musicman360 in forum Ferrari Talk
    Last Post: 06-12-2005, 06:03 PM
