Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Covid-19
    francisn is offline Post whore with no life, no friends, and a problem fitting into normal social circles Admin dude
    S. England, but Scottish!
    Francis Newman
    16,910
    How nervous was I drilling into the leather and trim for the first time???!!!!
    Not one for modifying Ferrariís but overall Iím pleased with the result, although I should have put the mount for the top strap a bit further down. Still modified with oem parts
    Attachment 155454Attachment 155455Attachment 155456Attachment 155453
    Great job Adrian
    11,109
    Hadn't read your first post properly, Adrian, so hadn't realised it was for the foldable top, hence my question about whether you had the vinyl cover for your targa as it has studs to secure the targa to the bulkhead. Also couldn't work out how those straps were going to be long enough to go round your normal roof. All is clear now
    Nicely done, should hold the foldy in place well.
    irarref is offline Nowhere to put the shopping -The Ferrari F40 Club Member
    3,397
    Very nice Adrian - looks factory :-)
    864
    So didn't take me long to get bored....
    Having taken the car for a little drive (obvious to go for some exercise ) last weekend with a separate satnav for the first time, I got a bit annoyed at the leads over my dash. One for the satnav to the fag lighter and one for the phone to the stereo; I felt some tidying up was required so will be fitting this over the weekend and doing some discreet hiding of cables. There are some USB sockets you can mount in 'dash', but I wasn't prepared to cut my console to do that!
    Now also tempted to fit a wireless charger for the phone in the centre console! Anybody done this? (Will I be bored enough next weekend; amongst the odd drive to go 'exercise' )
    Aug 2012
    South west Birmingham
    1,210
    i fitted the exact same kit (off amazon) in wife's car so the tracker system(hidden) had power always with a preset battery limit box so battery wouldn't go flat.
    I am ready to fit the same into the 328 also as i need more USB gadgets than the one cigarette lighter socket which is a pain as you said Adrian, the wires going all over the place.
    i have a small open storage compartment to the right of my knee so i'll install there, you'll never see it.
    good luck, great little bit of kit for a few quid, ideal addition
    864
    Think I might need therapy...!
    Since the camshaft seals had been sorted, this little tinker of a leak was apparent. Right sod of a location, up by the engine mount/ac compressor. Not enough room in any direction to actually get your hand properly on it.
    Long extension needed; inboard side washer had to be put in location with some long nosed pliers due to the access and what lovely expensive washers they are. Hadnít come across dowty washers before!
    The rubber/plastic on the old ones feel very brittle; age and heat I guess; but also looked like one had been pinched somehow.
    Still new ones in and a quick run up with no leak; so fingers crossed thatís sorted!
    A few others packages came with the washers for a bit more tinkering this weekend! (Would a therapist needs cheaper?)
    Aug 2012
    1,210
    those washers are great, they have a rubber inner, so act like a O ring and seal from drips.
    i have them fitted to all 30 plus studs on my oil/trans pan
    if there the same thing
  1. Driving a Ferrari just now... (COVID-19)
    By BlueIn2Red in forum Ferrari Talk
    Last Post: 30-04-2020, 05:55 PM
