Page 1 of 35 12311 ... LastLast
Results 1 to 10 of 343
    Mike01606 is online now Kid's bed - The Ferrari F50 Club Member
    3,635
    Default My Argento 360
    Thereís a lack of 360 technical threads at the moment and Iíve just started some winter work on mine so I thought I start a thread.
    How deep I go is open ended and very much depending on what I find but starting with fitting the exhaust I refurbíd in the Summer and the rest will depend on what I find.
    Iíve my eye on a couple of jobs but Iíll leave those for now and see where it takes me.....
    Itís been a few years before Iíve had the time and space to spend a bit of time and it keeps the cabin fever at bay over the long winter nights!
    First job grill and rear bumper off which is well covered elsewhere.
    Only thing to point out so far is you can get at the outer bumper bolts without removing the wheels and grit guards if the grill is off. A bit fiddly but more convenient for me as Iím tight for space at the side of the car.
    First question.....I intend to replace a lot of fasteners and p clips etc with stainless. Has anyone got a recommended source?
    Modificato is offline Looks like a 308 to me? -The Ferrari 288 GTO Club Member
    2,851
    Brilliant news:-
    Have longed for a good 360 thread - I personally think the tasteful upgrade potential for this tipo is massive.
    Will also be good to see what condition they are in underneath.
    You already have my undivided attention
    3,635
    Iíve realised this afternoon this wasnít a great time to start as Iím away for most of the next two weeks....
    Iíve just a spent an hour this evening stripping parts off and will continue tomorrow then it will stall for a while.
    Exhaust outlets off....far too easy considering itís probably 5-6 years since it last came off and the heat involved.
    A tip if your buying a second hand silencer. Check all four studs on each side are OK, as most I see on eBay have some of them sheared.
    I used two axle stands to take the weight of the silencer to stop it stressing the manifolds and removed all the brackets.
    The silencer is a tight squeeze but came out ok (but watch your paintwork)
    Lots of white powder on top of the gearbox. Hopefully this will see and to that.
    Cats look good from the back..
    The only other thing I did was strip the heat shielding off the rear of the box and F1 actuator.
    Adam mentioned a leak on the actuator position switches which he says is very common in fact most cars have it.
    Itís hard to see and it all needs a good clean but the selection sensor is damp. The engagement sensor is bone dry.
    This is gearbox oil not F1 fluid at this end of the actuator BTW.
    This was pointed out 12 months ago and the long-term issue could be oil ingress into the sensor causing a fault.
    The sensors themselves are plain old PSA group throttle position sensors?and I have a few spares!
    So....should I leave it as the car drives so well or dig a little deeper?
    Iíd like the think that there is a seal on the shaft that operates the sensor that I could replace without removing the actuator and fully stripping it but Iíd prefer to know that before starting.
    I have the software to carry out a F1 relearn afterwards but havenít tested it.
    Could it be that easy to fix ? I doubt it....
    Otherwise all good so far. You start these things with a bit of trepidation in case you find the weld where the two halves were cut and shut or something worse.
    Eg the bumper has had no repairs and matches the cars age and a good thing about owning an Argento car is that that most of he spares have red paint on and thereís usually some overspray left behind [emoji4]
    The exhausts are a nice colour internally
    I intend the remove the airboxand side panels later this week and the try and give the engine bay a good clean and degrease. The gearbox casting looks very clean and will clean up like new.
    One final picture.....
    Dust is great for showing leaks....I had this inside the rear bumper and it looked like carbon/soot.
    After a bit of to and fro. It was Meguiars tyre black thrown off the new rear tyres!
    11,188
    Brilliant news:-
    +1
    A348W is online now Rear lights like a farm gate - The Ferrari 348 Club Member
    935
    I used asap-supplies.com for my S/S P clips.
    The metal band is not quite as wide or thick as the F cars ones, but about a tenth of the price.
    No affiliation to the company, I just use them for various boating bits!
    (Keep your thread going, I like these!)
    Cheers
    1,470
    Nice to see someone doing sensible work on their car. I regard this as extreme cleaning and its so satisfying when you put everything back together - shiny new and niggles sorted out
    3,635
    Thanks for the supplier advice....Iíll look into it.
    On the actuator leak......
    Itís hard to find any detailed images that show how these sensor shafts may be sealed.
    This is the best I could find.
    Looking at the engagement switch on the end of the actuator. The brass part can only be installed from the outside and could be retained with a circlip?
    If that is the case the selection one (which has the black plastic cover on) could be the same and looking at the casting I think it is similar unless the black cap is actually the seal.
    I also found one for sale with the selection sensor shaft removed/missing.
    I need to move the F1 hydraulic lines to the side to get clearer access and probably need to remove the air box as the F1 lines are P-clipped underneath it.
    So far it looks like it is possible to reseal these switches in situ.
    If anyone has any detailed images of an F1 actuator with the switches removed it would be great fully appreciated.
    One day I would like to strip an actuator down to de-mystify them but Iíll only do mine if totally necessary.
    3,635
    Just reading my posts again.....Iíve reversed the selection and engagement sensors.
    Selection on the end and engagement on the bottom.
    The leak is on the engagement sensor.
    Jul 2009
    Aldous Voice
    3,590
    The leak will be coming through a seal in the area where the finger engages with the gearbox. This is why you're getting transmission oil egress as opposed the F1 oil. Very common on all F1/CC tipos but the 360 sensors seem to be more oil resistant than the ones fitted to the later actuators. Unfortunately you'll need to strip the actuator down to get to the seal.
    If you email me tomorrow I'll take a picture of the seal - I have an actuator in bits right now.
    3,635
    Quote Originally Posted by voicey View Post
    Awesome Aldous and thanks.
    I was going to try a post on FChat later to try and get an image with the sensor removed....
