Results 1 to 10 of 16
Thread: 360 wont start / turn over ?
    Mar 2013
    Ireland
    17
    Default 360 wont start / turn over ?
    My 360 wont turn over.
    Everything seems ok, the remote unlocks the car, the F1 pump runs when you open the door.
    Turn the key, engine check OK, N on display, but when you turn to start nothing !
    The battery is good and the engine lid is closed. Yesterday, I turned off the battery kill and back on, it then started and I let it run for 15 minutes to get to temp, but today the issue has returned.. any ideas ?
    Nosevi is online now Post whore with no life, no friends, and a problem fitting into normal social circles Super Moderator
    11,334
    Immobiliser perhaps?
    Mar 2013
    Ireland
    17
    I dont think so, the remote is operating the immobiliser led and usually the immobiliser allows the engine to turn but not start. In this scenario, its not turning over 🤔
    A348W is online now Only 37 known common faults - The Ferrari 355 Club Member
    1,018
    Battery just enough dead that it will turn lights etc on but not crank the car? Had similar in the past with cars.
    Mar 2013
    Ireland
    17
    If I turn off and back on the kill switch, then the car will start so the battery is good.
    11,334
    Quote Originally Posted by FerrariIRL View Post
    Does sound like immobiliser from that. My immobiliser kills the ignition so it won't turn over if it's 'fired' unless you reset it.
    6,684
    Brake pedal switch will cause this, press the pedal really really hard 👍
    Allandwf is offline Essex boy's Ford Capri Club Member
    Jun 2009
    Angus, Scotland
    Allan Fisher
    148
    I tend to agree with the others re battery. No harm in trying a new one just to eliminate it decisively.
    3,654
    I had similar on mine.
    Everything seems fine, F1 pump runs, check ok lights etc then when you turn the key to pos 2 nothing....
    It did it intermittently for a couple of weeks.
    It was the high current starter solenoid contacts which power the starter motor itself.
    You can buy repair kits but I just ended up cleaning them.
    Ask someone to turn the key and listen carefully for it clicking. If its moving and not pulling the motor in, the contacts are burnt.
    3,654
    The last pic is a trace of the fixed contact shapes as the kit I bought had the right plunger but incorrect fixed contacts.
  1. OMG - missed the turn?
    By philworrall in forum Lounge
    Last Post: 18-12-2008, 11:29 AM
  2. 430 U Turn
    By Elms in forum Ferrari Talk
    Last Post: 12-08-2008, 11:59 PM
  3. Its now the turn of the F360s
    By ferrari-spider in forum Ferrari Talk
    Last Post: 17-10-2006, 08:25 AM
  4. Turn the volume up
    By stevew in forum Lounge
    Last Post: 01-10-2006, 11:07 PM
  5. F348 side strakes - turn on or turn off?
    By Jas in forum Ferrari Talk
    Last Post: 17-07-2006, 08:16 PM
