Results 1 to 6 of 6
Thread: 355 tripping hidden 30amp fuse
    Jul 2018
    Ben
    43
    Default 355 tripping hidden 30amp fuse
    Hello
    I have an issue with my LHD 96 355 spider 5.2 where the hidden 30 amp fuse is constantly blowing, this is currently on a circuit breaker so I need to keep resetting the breaker, it usually trips again less than a minute later. I would like to finally fix the underlying issue.
    Can anyone help me troubleshoot, I’m not sure where each component is located, I’ve read that disconnecting relay 04269 will rule out the clutch compressor but I’m not sure which relay this is, the manual doesn’t seem to pinpoint this?
    A348W is offline Only 37 known common faults - The Ferrari 355 Club Member
    1,107
    Rings a bell. Have you searched fchat?
    Jul 2018
    Ben
    43
    Yes, That is where I read the relay tip, however I wasn’t able to find where it was situated.
    I have created a thread over there also, The car will be having an engine out service in due course so would like to determine the cause to this issue beforehand so that I know if anything in the engine bay needs replacing at the same time
    3,500
    Does it make a difference if you keep the fan speed on your heater very slow?
    I'd suspect your "powerpack" which is in the front boot. Sadly a NLA part but Miro on FChat has a thread (which I cant find) about repairing/upgrading them
    Jul 2018
    Ben
    43
    I donít believe that did make a difference, I am sure I have tried alternating the speed.
    Powerpack, havenít come across that. Iíve read the compressor or heater valve motor is usually the culprits to this issue.
    Mar 2015
    Sydney
    Ian Riddell
    139
    The "powerpack" is another name for the fan regulator.
  1. Fuse
    By zambesi0 in forum Ferrari Talk
    Last Post: 28-03-2019, 03:46 PM
  2. 355 FUSE BOX HELP!!!
    By cappsy in forum Technical Q & A
    Last Post: 16-05-2009, 07:44 PM
  3. any hidden 550's?
    By goldsax in forum Ferrari Talk
    Last Post: 12-02-2007, 06:52 PM
  4. 456 Fuse box
    By andy456M in forum Technical Q & A
    Last Post: 01-11-2006, 12:00 AM
