Thread: 355 water temperature gauge not working
    Mar 2012
    over the hills + far away
    alan neill
    7
    Default 355 water temperature gauge not working
    As the title says, my gauge isn't working. I've replaced both the sensors in the engine bay without any success. Obviously the gauge itself could have failed but is there any relay or fuse involved that I could check? I have a 1997 5.2 Motronic.
    I've searched for a wiring diagram without success online. The workshop manual I have isn't too helpful.
    Any advice would be very gratefully accepted. Thanks, Alan
    Mar 2015
    Sydney
    Ian Riddell
    152
    There are no specific fuses or relays. Did you apply plumbers tape to the threads of the new sender by mistake? The sender uses the engine as an earth.
    Instrument wiring diagram here (5.2 car):
    https://www.dropbox.com/t/QBP4XkhnwJFLsxY8
    Temp sensor is labelled 04706
    Link expires in 6 days.
    Mar 2012
    alan neill
    7
    Thank you so much Ian, so very kind of you. Regards, Alan
    Mar 2012
    alan neill
    7
    Now working. Great help. Thanks again.
    Mar 2015
    Sydney
    Ian Riddell
    152
    My pleasure, Alan, but what was the problem (for future reference)?
    Mar 2012
    alan neill
    7
    It was the little brass contacts in the instrument binnacle. I didn't see it myself but my mechanic friend told me of a thin paper / printed circuit being loose. As far as I know the binnacle has never been removed in my ownership (18 years). All sorted after the brass nuts were tightened.
    Mar 2015
    Sydney
    Ian Riddell
    152
    Thanks, Alan. I was going to suggest looking at the nuts, but forgot. Glad you found it.
  1. 348 Oil Temperature Gauge stuck on zero
    By eee348 in forum Technical Q & A
    Last Post: 31-01-2011, 12:52 AM
  2. 348 water temperature
    Last Post: 27-05-2010, 11:00 AM
  3. 348 water temperature
    Last Post: 09-10-2009, 06:18 PM
  4. 348 Fuel Gauge not working
    By mgdave in forum Technical Q & A
    Last Post: 12-04-2009, 05:43 PM
