Results 1 to 5 of 5
Thread: Adding a 'Bumpy Road' switch to put suspension in comfort while in sport on a 360
    Dec 2021
    Staffordshire
    Rob Farmiloe
    14
    Default Adding a 'Bumpy Road' switch to put suspension in comfort while in sport on a 360
    I see this has been done before and is simply a switch to interrupt the signal to the ECU.
    Anyone done this themselves?
    Thanks Rob
    2,527
    Hmm, I'm not really sure why you'd want to do this. The 360 doesn't really have a 'comfort' setting. They're either pretty firm or more firm
    Dec 2021
    Staffordshire
    Rob Farmiloe
    14
    The switch when fitted puts the car in sports mode but leaves the dampers in standard setting which gives better handling on less smooth b roads.
    Basically the same as the shock symbol on a newer car like the F8
    Jul 2017
    Notts
    Andy
    51
    Rob,
    give Aldous a call or e-mail at AV engineering (http://www.avengineeringltd.com). He sent me some instructions - wouldn't want to just cut-and-paste them on here without his permission, but I'm sure he'll send them to you.
    Andy
    Mar 2015
    Sydney
    Ian Riddell
    169
    I'd be curious to know how it was done, too.
    On the 360, the SPORT switch is wired directly into the Suspension ECU (nothing else). It must be the Suspension ECU which tells the Engine ECU and F1 TCU (if applicable) that the SPORT mode has been selected (on data lines). I can't see how you could tell the Suspension ECU to ignore the SPORT switch and not affect the other computers.
    Interrupting the SPORT switch wiring going to the Suspension ECU with another switch stops everything.
  1. 360 Modena Sport Switch
    By Si_man in forum Technical Q & A
    Last Post: 17-01-2020, 08:27 PM
  2. 360 - Comfort or Sport mode?
    By asl_911 in forum Technical Q & A
    Last Post: 16-09-2014, 04:21 PM
  3. 360 Modena Sport Switch .....?
    By Sidester in forum Ferrari Talk
    Last Post: 28-03-2009, 06:32 AM
  4. Bumpy ride at speed.
    By andy456M in forum Technical Q & A
    Last Post: 25-12-2007, 08:33 PM
