That is odd.
There are some good threads on Fchat about this with lots of pics etc. I looked into it once as its a common problem and the windows were the usual slow! I dont think you need a manual, you just need to make a sketch of what colour wire goes to which pin in the socket.
Basically there are three approaches from memory:
1) get new wiring harnesses and fit them. But just checking farrariparts and superformance they are currently unavailable.
2) you can get new individual wire connectors (pins etc) and re do the sockets, problem with this is that there might not be enough wire to cut the old connectors off, and get back to clean wire, as the ends will be most likley corroded to a certain extent, and hence option 3
3) you can cut the exisitig sockets off, cut the wires back to clean wire, add on new wire to get back to the connectors and re do the connector.
Dont forget that if the door side is gone, then likley that the other end in the frame will have some issues as well, believe you can get to it from the wheel arch but cant recal.
Good luck and lets see a Jeff esk post thread with lots of pictures!
