Hi!
I recently bought my new 360 Coupe with the F1 box, and i am new to this site, so appreciate your help in advance.
Today, i took it out for a spin, but what a disaster! I came to a roundabout, and put it into neutral. Tried to move up to 1st, but it would not go. Pressed the Auto button, and it jerked into 1st gear.
Travelled a bit further to the next round about (upto 4th gear), where i again put it intocycled down through the gears, and then into neutral at a standstill.
At this point the car, would not engage any upper gear or reverse.
Being stuck in the outer lane of the dual carriage way, i got a bit frenzied! Turned the car off several times and still the same issue. Eventually had to be recovered and transported back home. Not good to wait for Green Flag for 40 mins when you got a 100 people passing by and shouting "get a proper car" at you!
Anyway, got back to my home, and the recovery guy left. turned the car on again and the car would cycle up through the gears without a problem.
There are no warning lights on, and the car after being off for half hour or so, does make the pump noise when starting up as i open the door. This lasts for about 30 secs-1min as normal, and then is quiet.
I dont know when the clutch was done previously. The car is just coming upto 19k on the clock.
Any suggestions ???
Thanks once again
M
Any suggestions ???
Thanks once again
M
