OK, so I wasn't going to be touching the body yet, but a few things were annoying me to look at, so started doing a little bit here and a little bit there, which escalated into many, many hours of bodywork fettling, resulting in what just happened now.....
Not the best photos as yet, as it's a bit cramped in the prep/primer bay as it was wheeled in there semi-whimsically while I still had panels for something else I'm building.
In short, it has had quite a heavy coat of primer, which helps show some of the areas which still require work. As we've been working semi-blind so to speak as we didn't know what had been done before and digging backwards as far as I really could, it's actually not too bad. There are a few areas which still need a little work and we've found one small dent, which was not visible previously, but overall I'm pleased. The back panel hasn't been touched as yet as the rotisserie has only just been removed this afternoon, so it still requires a lot of work prior to its first coat of primer and it's actually the worst panel on the car and will take some serious repair work.
The bonnet was also quite badly distorted from the soda blasting, which is partially surprising given how gentle soda is compared to other types of blast media, but it can still happen. It is, however, nearly there now.
We're going to leave the primer for probably around 2 weeks before touching it again now, then it will be blocked, re-work anything that requires it, followed by a very thin final coat of the same to flat. The car will then be painted all over in gloss black as a "test" coat so to speak as gloss black will show up the tiniest of imperfections, then that will all be flatted back prior to being treated to its final colour. I want it to be painted in Glasurit paint as that is what it would have been painted in from the factory. Albeit, we will be using a more modern and improved basecoat and lacquer. It's probably still the most expensive paint on the market and it's a bit of a pig to work with compared to some other paint brands available nowadays, but I'd rather stick with the brand that Ferrari originally used, plus the results should be stunning and the warranty on their product is streets ahead of anything else on the market.
Also, the underside will be treated with a hot zinc gun and Upol Raptor, which is probably the best protection available against corrosion and general road damage currently.
Hope to update again soon and I will be sorting through the 19 crates of parts that currently reside in my garage at home on Tuesday evening. I've made a start, but want a couple of other people around to assist me so as nothing gets mislaid or mixed up.
