My 348 was in storage for 10 years, so now I am retired I have more time to play so the first thing was new cambelts, thermostat, waterpump, plugs etc.
So now we are running and she pulls great and a smooth tickover, the right bank is ok but the plugs on the left bank are all equally black with a whitish tip, there is white oil smelling smoke from the exhaust and oil around the first exhaust joint.
All 8 cylinders have the same 11.75 bar compression, I have reset the resistance in the MAFs and swopped them over with no difference, I have tried the Italian tune up with no difference. (I am chased down the road with white smoke). There is no oil contamination in the water and vice versa. All the 4 plugs on the left bank are exactly the same so if it were a valve stem then surely it would only be one plug. If it was a head gasket then it would affect one or two plugs, I have swapped over the pressure relief valves with no difference. So what is putting oil equally into all 4 cylinders ??? Please help.
