You need to remove the inner wheel well liner on both wheels and also the trim coverings inside the door (including the panel that the lock plate is on). There are also screws holding it underneath the car.
It's been a while so I may have missed something off the list but if you take your time to uncover the fixings and are careful you should be able to figure it out. Good luck!
