Ferrari F360 ASR cuts off engine (software)
HomersHK
Got a F360 Spider 2001. Been having issues with my ASR suddenly cutting off engine power allowing around 1300-1500RPM only, even when pressing the accelerator. It's a software cut-off. My garage thinks it's related to sensors that need replacing. I've had the issue 4 times now (over about 6000km within 8 months). Usually happens in a traffic jam with the car overheating. Need to switch off the engine, wait for 10 sec, turn it on again and the problem is gone.
Any suggestions? See a short video attached.
Notorious for being a bad battery causing this.
Is the car left on a battery conditioner?
How old is the battery?
Battery tenders can mask a basically dead battery
Other items in order of likelihood:
ABS / ASR electronics
ABS/ ASR Pump
Slip / motion sensor gone bad - Integrated into the wheel hubs
[These are three black boxes one is under the left engine bay cover, one is in front of the windscreen under the cover panel near the master on/off switch. The last is under the front bumper. All three are bolted onto the chassis.]
I would pay / ask for a full system scan to narrow it down before spending lots of money on each item.
I’d add bad earthing also.
I used to see an ASR light sporadically when there was no slip.
I cleaned the under bonnet power cut off switch connections and where they bond to the chassis.
F360 sudden ASR cut-off (but engine keeps running at about 1200rpm)
Hello Modificato;
Appreciate your input, thx
- battery is almost new (about 4 months)
- car is now at the garage; clean bill of health. No issues came up with the scan (as in, nothing no other problems either). They recommend cleaning the sensors and doing a reset. I've forwarded them your recommendations.
Lets see
Hee guys.
still having my Ferrari 360 spider ASR cut-off issue.
Has happened maybe once per 3000km so it's wasn't a huge issue but yesterday it was quite alarming.
Previously ASR would kick in cutting the engine revs to about 1800 at most, when the engine overheated eg in stop and go traffic. Annoying but manageable.
However, yesterday I downshifted from 3rd to 2nd gear to overtake a car and BOOM, ASR kicked in (cutting rpm to about 1800) forcing an emergency stop on a dangerous spot.
The engine was warm/hot, nothing special. Good grip, smooth downshift.
When turning the engine off and on the problem resolved itself. My garage just finished the MOT having cleaned all sensors, while not finding anything irregular.
Suggestions are appreciated.
Also, speaking of software-related issues, if you ever find yourself dealing with app development for your car's navigation system or any other related tech, you might want to check out https://www.cogniteq.com/blog/navigation-app-development-step-step-guide. It offers a detailed, step-by-step process that could be helpful if you want to get into developing or improving automotive apps, from design to deployment.
It sounds like you're dealing with a classic ASR (Acceleration Slip Regulation) issue, which is often tied to either a sensor malfunction or a software/ECU issue. The fact that it happens mainly when the car is overheating and you need to restart the engine to clear the issue points towards potential issues with temperature-sensitive components.
Here are a few suggestions that might help:
  1. Check the ASR sensors and wiring: As your garage mentioned, sensors can be a common culprit. Specifically, the wheel speed sensors, throttle position sensors, or even the engine temperature sensors could be malfunctioning, causing the ASR system to restrict power. Check for any damaged wiring or connections, as these can sometimes cause intermittent issues.
  2. Overheating issue: If the problem happens during overheating, it might also be a good idea to investigate the cooling system more thoroughly. Make sure the radiator, water pump, and thermostat are all functioning properly. Sometimes, if the engine gets too hot, the ECU might cut power to prevent damage.
  3. ECU software update: Since you mentioned it seems like a software cut-off, it’s worth asking your garage if the ECU has the latest software updates. Occasionally, there are fixes or recalibrations for known issues with the ASR system that are addressed via software.
  4. Throttle body or accelerator pedal sensor: There could be an issue with the throttle body or accelerator pedal sensor, which could confuse the ASR system into thinking there’s an issue with wheel spin or acceleration, causing it to limit power.
  5. Check for stored fault codes: Even if the problem clears after a restart, it's worth having a diagnostic scan done to check for any stored fault codes that could give you a better idea of what’s going wrong.
Since it's an intermittent issue, it might take a little time to diagnose, but starting with these areas should help narrow down the cause. Keep an eye on the temperature gauge too – it’s worth ruling out any overheating problems as the main trigger.
