Hi Kev. Yep, I've got one and it's excellent, does exactly what it says it will. I've got a particle tester (forget the posh term) and our water is normally terrible for washing cars, water marks everywhere. I used to have a more expensive filter from another company but found the one from Race Glaze is far better.
Full disclosure - I know Mark who owns Race Glaze well...…….. but the numbers don't lie - the Race Glaze filter was far more effective and took out more particles, lasted longer, was cheaper and is rechargeable (you don't need to replace the whole thing when it stops working, just the stuff inside). I highly recommend them :thumbsup:
Thanks for the feed back.
Are you using them for just your final rinse or your whole wash cycle?
I have one of these from Mark and it still leaves spots on my car so still have to dry it down with a towel.
Leaves horrible tide marks on the 458 front aero wings as it is a concave shape so a small puddle collects there. So if I forget to soak up the water a nice mineral ring remains.
Don’t have a particle reader so don’t know how well it is working or ever worked. Only had it 2 years I think and it’s not used that often so the resin should still be good.
Just my experience.
Buy a particle checker to make sure it is working OK. Mark sells them but I bought one from Amazon for about 10 quid. Also useful for checking my home water softener is working properly.
+1
I test mine before using it each time and it gives near zero ppm having been through the filter, probably have pics to show that somewhere. No particles means there’s no impurities to leave a mark other than what the water pics up from the air while it’s evaporating. If you’re getting marks my guess is it’s not working properly.
It might be grim up North but at least our water is pure and clean
I’m fascinated by these threads as I don’t think I’ve ever seen a water spot using Wales’ finest.
