RobC
Well, I have been trying to get a garage/workshop to hire out for my servicing ,I could not find anyone who was willing to loan/rent a place locally to me in Essex.......
So,after five months of mucking around I bit the bullet and started getting quotes from Indy's and then onto Main Dealers, I ended up using a Main dealer here in Essex..they said they would be competitive and were willing to match the indy's quotes........................
Ok so Cambelt and service is usual for most every three years,I also had problems with rear camcover oil leaks(quite common apparently on 348's, I also had a worrying chain clanking noise when the car was cold, once warmed up,this noise would disappear and everything was fine,or so I thought........................
A phone call has been received evry day so far since Wednesday when it was picked up as to the progress of the problems............Intially they thought it was a front bearing belt tensioner, then it was a broken valve spring....Nope......it was definately from the oil pump chain drive area.................................
A day later,the engine was out...........sump off,and then they found this noise source, a broken /sheared driftpin/slipperpin on the gear which drives the oil pump gear,somehow this has also altered the whole timing issue whith the cams and is running slightly rough......
I had noticed that the performance had dropped slightly but thought it was to do with a sparkplug/ coil issue as the tickover has been rough for months and months, in hindsight this was to do with this single pin which has sheared ,so I am off to Lancasters tomorrow to be shown the problem,and will be armed with usual cameraphone for some interesting pictures of which I shall share with you all........
