swnyradar
I fitted new front discs last year but they had no paint or any protective coating on them and have since started to rust on all the non-contact surfaces which doesn't look very nice..
A fellow cs member I met last year recommended I get them acid dipped to remove the surface rust and then zinc plated to remedy this, with the idea that the only few micron thick coating will come off the braking surface as soon the pads come into contact during braking, leaving the rest of the disc protected and corrosion free.
I've found a local firm to do the dip/coating but thought I would see if there are any potential issues with this process?
