Same as the 328, O ring and seal. Same leaking design.
I wish I had a press when I did mine, had the use two pieces of wood and squeeze together in my workshop vice.
I’m sure you know but make sure those valleys line up the oil return hole in your engine block, as they easily turn when you put your cam covers back on, and can be out of alignment, found that one out twice now, so mark edge of ring and block with marker pen.
That looks like you've had the oil drain mod done???
Cross reference against pics here:
https://www.ferrarichat.com/forum/threads/328-cam-seal-oil-drain-hole.267158/
Looking good
