Hi,need some more details. you imply you are leaving the engine running when you are filling the tank? does the engine only cut out then?
Not the engine is stopping, but the gas pump.
When I fill in the petrol, the pump stops, detecting the tank is already full (even when is almost empty). It looks the pressure inside the tank is going up, to it is being detected as full already. I was able to fill only ¾ with around 4 or 5 stops.
