348 DIY "Restoration"
Such a shame and I'm sorry to hear you're selling the car. Whoever becomes the new owner can be sure the car was well loved. Take care.
Cheers guys - the sentiments are appreciated :)
For all you TS/GTS guys I've just listed my foldable targa softtop so just PM me with any interest.
Had a very busy bank holiday yesterday - started around 10am and it took me till about 5pm just to get the bumper and front wing off. I know all about the "hidden welds" on a front wing and now have a new respect of the strength of mastic/seem filler or whatever it is!
Hoping to get the driver's side wing back on and the passenger side off today - assuming all goes well! I'll post the full story when I've done as have taken a ton of photos - took a lot longer than expected :-(
Sorry to hear about your health, job and selling the car. We never know what is in store and the older I get (60 next month FFS) the more I get concerned. Had a Ferrari since September 2004 and although I had a momentary lapse of reason post covid I have fortunately kept hold. I know it can't be easy for many reasons. Wishing you better health, a new job and perhaps another Ferrari soon.
Cheers guys - much appreciated. Really struggled with fitting the front wing so gave up and took it to my friendly bodyshop this afternoon. I just couldnt get it to fit with an even gap btween the door and strake panel. He's just sent me a photo of the initial fit and all is looking good, Got a bit carried away whilst I was there and going to get a few other little bits and pieces done atthe same time :) First time in 12 years I've not had a Ferrari in the garage and I don't like it! :-(
Hi Jeff, I too have watched your thread with great interest. You are a brave, patient man :). I have owned my 348 for about 20 years and have often thought of selling as I don't use it much, but cant seem to do it.
I see you are based in the north west, me too.
What body shop did you use as they look to have done a great job. Mine will need some TLC eventually and it would be good to get a body shop recommendation for when i eventually come to doing it
Cheers
Bodyshop texted me before to say I can pick my car up tomorrow :)
The front wing is all done and the skirt etc. put back on. I'm also having the stem of my wing mirror repainted as it was starting to bubble. I just need to fit the wing mirror when I get there plus reapply my fender shield when I get it back home.
Rot at the bottom of front passenger wing was cut out and the Ferrari repair panel cannibalised to make a repair patch.
There was a bit of rust just on the edge of the wing near the bumper that has been treated and blown in (sorry forgot before pic).
As mentioned earlier in the thread just as I was about to embark on a road trip the seat back adjustment broke and after taking the back of the seat off you can see what's wrong here. Despite spending an age undoing the fiddly bolts securing the twisted plate, straightening it, and then rebolting it back it just didnt work very well so in the end I bought a pair of rough seats off eBay for £200 and made a 500-mile round to collect them.
Here's the driver's side seat. The plan is to seperate the seat and the back and transfer the back with the working mechanism onto my seat. Unfortunately I just cant replace the whole seat as the seat part has ripped leather.
The bolts securing the seat to the metal bracket joined to the back pass through the runners so using an alan key I undid all the bolts I could find - you have to slide the runner about to expose some of the bolt heads that can be accessed through a hole in the runner/
All was going well until one of the bolts rounded and was well and truly stuck.Long story short I had to use an irwin bolt grip to undo it which involved filing off the little tab on the runner so the slider would go further than it should to expose the bolt head. GRRR!!!
Old seat in 2 pieces - now to repeat the process on my lovely shiny seat - but with broken mechanism :-(
Now its time to separate my existing seat into it's 2 parts.
Curiously there were a different amount of bolts on this and a slightly different style too.
Once they were separated i cleaned out the threads on the bottom of the seat using copper ease and repeatedly screwed the bolts in and out.
The only fly in the ointment was that the seats I bought had the later style lever for adjusting the recline and you can't just swap the levers over as the panel they go into is a different shape. After removing the lever itself just ease out the plastic lug.
The panel behind can just be tugged away from the seat.
The other side panel is just held on with a plastic lug although one of mine snapped upon removal as it was brittle with age.
Not the best pic but now I have a fully working reclining seat made up of my original seat base connected to a new style but scruffy seat upright - nearly there!
It's actually just the top-right panel that you need to swap over ie the surround round the lever. I just redyed them with my dye so it matches the seat base.
The seat bolsters were rubbed down with wet and dry along with a magic sponge with acetone to remove the worst of the cracks/creases
Then a few layers of dye to restore the surface.
Another curiosity/problem is that the later seats dont have a bolt hole to bolt on the shoulder seat belt guide - actually explains why I see so many later cars where the belt goes straight from the reel which I dont like TBH.
Need to find a solution as to what to do with the belt guide - do I just cut it off and will I have to cut other side to match????!!!
Here's a comparison of the old seat back with a bolt hole for the guide, the matching back with hole and the newer style back with no hole for guide.
In the end I drilled 2 holes in the back of teh new seat back and threaded a bolt and washer from the inside to the out so I can put the guide on and then put a nut on to secure it (epoxied in place as you won't be able to hold the bolt head once the back is screwed in place.
Mock up before I applied the epoxy
All the screws for the seat back ready for painting
Once the bolt was expoxied in place and the new back dyed it was screwed back on the seat. To make things easier I used toothpicks to locate the holes - very fiddley job.
h
All done - youd never know the difference apart from I have a the shoulder seat belt guide as per earlier cars but the later style recliner lever. Only dilemma I have now is whether to do the passenger seat so they match....mmmm!!!
Now to make the passenger seat have the matching recliner lever. I was dreading doing this as it was so much work doing the drivers side then it suddenly dawned on me that I might get away with just swapping the surround panels and the lever :)
First remove the lever which is held on by a captive alan bolt
Panel just pulls away then.
Plastic lug just pushes out
Other side is just held on with a wheel arch liner type plastic stud
All the bits ready for cleaning up
On the lug side there is a little bracket screwed on to receive the lug so that needed transferring to my original seat back.
Ready for dying
One panel dyed for comparison purposes.
Close-up of the panel lug. I actually colour-coded these as they look silly being a black dot in the middle of the seat.
To help seat it I used a screw driver inserted into the hole for the plug to make it easier to locate the panel in the correct place.
And the end result - driver's seat with a working recliner - both seats upgraded to the later style lever pulls and both seats retaining the shoulder guides - very pleased as it took me the best part of 2 days to do it all including all the dying. I also raised the old seats to get a better matched set of screws so I can secure my seat backs a bit better as the passenger one was a bit loose.
